My 300 horses won't run.
JohnlukePiccard
Mar 3, 2005
Indiapolis, Indiana
I Swapped out my auto trans for a manual. I swapped everything. I got fire to the plugs, fuel to the rail, and it turns over. Won't hit for shit. I don't know if the timing is off or what. :mad:
Do a compression test. If you get poor compression your engine is trash or your timing belt is off. Also check your coil pack, power transistor, AND the Cam Angle Sensor.
