Car won't run....
TsiRevolution
May 10, 2007
Harvey, Louisiana
Ok I have a 1990 talon awd.
I just installed a AFC, Boost Controller, AEM Wideband, Oil pressure gauge,EVO 550 Injectors, new stock o2 sensor,EVO III 16g, and a new battery.
After spending a few nights getting everything installed change the oil and go to turn the car over. It cranks a bit because it hasnt run in two months, finally it runs for a second and then dies. If i give it a little bit of throttle while starting it, it will stay running but rev very high. Im thinking it has something to do with the stock o2 sensor or the afc.
Any thoughts?
did you set your afc to the proper base settings? not configuring what type of airflow measuring device would cause this issue
yeah you need to set up your afc...those new injectors you put in are probably throwing it off with too much fuel
I have an old school 5 knob afc. I cant find a manual for it anywhere online. I need to know the settings for the dipswitches and the car type knob on the back.
