Multimeter help needed
DNA666
105
Oct 29, 2002
Anchorage, Alaska
After a rebuild my #4 injector isn't firing.
Does anyone know how to test the fuel injector resistance pack, power transmitter, and fuel injector plugs on a 2G GSX?
THX
before you do any electrical tests...maybe you should check the injector...make sure its not clogged....
If thats not the problem...take a multi meter and it should read 2-3 ohms for a good injector.
I moved the injectors around and #4 is still not firing.
luv2rallye said:
Put noid light on it or measure voltage. If non, look for broken wire, blown injector #4 resistor (in metal box in center of firewall - 5.5-6.5 ohms), bad ECU or CAS.
could be the CAS...dont think its the ECU.
    • dsmmario
    • Detail
    • dsmmario
