mounting laptop in car
TalonFULLtune
107
7
Jan 15, 2013
three churches, West Virginia
ok im tired of having the laptop on the seat and I feel I want to mount it in a way where when not in use I can hace it under the glove box and when I go to use it I want to be able to pull it out and over faceing me so I can tune and watch my logs on the fly. any suggestions or any better ideas for a different mount. car is a 1g tsi[DOUBLEPOST=1414365922][/DOUBLEPOST]nobody has done this before?
I mounted a small Acer mini in the glove box in my 1g gs. Car had no dash cover but a glove box for my pc LOL
There's a great thread about this already, someone made a very nice one, fold-able and everything. I can't find the thread right now but I'm sure you can if you search for it.
thanks guys looking to get a mini of some sort. now do need to get one with a cd rom or can I transfer off my asus
Ram mount doesn't have anything for a 1G or 2G specific
If you search "car laptop mount" on eBay there is several setups to choose. When the time comes I'll purchase one.
I have a ram mount on my car, but mine is easy since I have no passenger seat or passengers. It's just mounted on a piece of half inch pipe. You can make any kind of bracket you can dream up to hold the actual laptop mount portion. It works pretty well though. Somewhere below 1.3 second 60 foots the lap top would open the spring loaded mount and fall out, so I turned it around so it opens forward. Now when I pull the chute over 175-180 it slides forward and still falls out. WTF. :D If you can keep the lap top mounted laterally for the most part it will work better. I deal with the spring loaded setup because it makes inserting and removing the laptop a 1 second affair. I may try some kind of non-slip rubber under the laptop to see if that holds it in place without giving up that advantage. Not sure if any of this helps or not.
I can find a picture if you want, but I use a Sony Vaio UX on a RAM mount when at the track. This way you only need to look straight, and can see if any knock or other abnormalities occur without having to look around any other gauges.
I am interested in seeing pictures of how people have done this. If you have time, snap a picture and post it up.
This may not help people with a passenger seat, but here is how mine is mounted. With a seat I'd probably try to come up with something that uses the two front seat studs and a point to the front or rear to triangulate it.
Roll bar mount
