window net mounting for swingout bars.
I responded to your ECMLink thread,
Same as other forum -
That is a tough one with a swing-out. You may have to integrate something into the A-pillar bar at upper and lower points to have as a pivot or clip-in then have a couple sleeves on the bar and halo area to mount into. Here is mine for example; as you can see, I have a fixed door bar, with a mounted pivot on the door bar, and a cable mounted pivot at the lower front. I have a sleeve at the upper halo point and a manual clip-in at the A-pillar.
See pictures in this link:
https://www.facebook.com/tim.zimmer.35/media_set?set=a.10216656151221970&type=3&uploaded=36
thanks a lot tim definetly gives me an idea. i know im going to need to have a custom net made. biggest thing is i cant find much info on if a certain amount of area has to be covered with the net.
