Motor rebuilt, do you have to "reset" sensors?
1990CherryTSI
Banned Member
62
Jan 24, 2004
Austin, Texas
Like the CAS, TPS? Do some parts have to be defaulted? For those who don't know I've been rebuilding a 90 TSI. I put a new (used but good) turbo in it, 4 layer HG, new pistons/rings on 1g rods. I put new bearings all around except main b/c I left the bottom end in the car. I have ARP in it, 2g exh mani, 2g o2 housing, new gaskets all around, cleaned everything out and had the head 3 angled/decked etc. Before I get ready to start it up I thought someone said something about defaulting the CAS? How do you default/reset and what needs to be defaulted/reset? I didn't see anything on vfaq about resetting or defaulting anything. The battery has been disconnected so the ECU should be ok, what else?
Thanks
ok gotcha, glad I still have all that apart. If the base timing is off and it has to warm up it won't cause any damage having it off (if it is) before I get to set it will it? Is the vfaq.com /engine one for the 1g the best how to that you know of ?
