Motor question
99 gst spyder
522
Jul 12, 2007
st. paul, Minnesota
I have a working complete motor that I took out of my car. Kind of low on compression but, I was wondering that if Its still good after a year in the garage on an engine stand? Or how long is too long?
Thanks.
Spark plugs in it?
Intake and exhaust ports plugged/taped?
If you have access to borascope, pull the spark plug and check the cylinder walls for rust.
As long as it is properly stored( away from water/snow. All ports to the engine are blocked so nothing can get inside) you can store an engine for a loooong time. Just make sure all gaskets are good before reinstalling it. ( if it was me I would just replace them since its out anyways)
As piece of mind, I would pull the head and oil pan. Ide apply oil to the cylinder walls and drizzle oil on any of the rotating surfaces ( i dont mean pull at the mains and con rods ) just cover things in oil.
If you want to stay away from pulling the head, I would definitely look to see if the cylinder walls are covered in rust using a (see snake/ borascope (as previously mentioned))
I would atleast pull the oil pan. Its easy enough and will definitely give you a good look at the cylinders condition.
Once you lube things up, try to rotate the engine @ the crank bolt. (make sure your timing is set or the cams are out)
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
