motor question
kpbrian
Sep 26, 2005
farmington hills, Michigan
I have a AWD Talon TSI with a non turbo long block, i have had some sugestions, but still searching for more sugestions on what the maximum and safe boost would be? also wondering while running lower boost due to this setup, is a goal of running low to mid 13's reasonable? thank you for any input.
well considering the internals of a 4g63 NT block are differant than that of a Turbo one.. wouldnt push more than 7lbs. the 420a 2g NT block can handle 5PSi of boost on a stock internal motor.
so for your question...i wouldnt go over 7 lbs. 6 to be safe. make sure you have all your other supporting mods as well. good luck man.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
