Motor Mount Bolt Size? (Timing area mount)
Clinical
1,398
11
Nov 15, 2009
Cedar Falls, Iowa
I tried searching and turned up nothing but 420a & tranny mount threads.
I found both of my bolts broke off in the lower end of the mount.
I've drilled and tapped them and gotten them out, now I just need to know what size/measurements of the bolts and am not sure where to get them from.
Being dumb I threw away the old pieces of the bolts so I can't put them together to check.
Just for clarification, this is the mount I need bolts for:
Thanks for any help guys!
They are part number MU240123. CAPS doesn't give a size for those. They are about $2 each at the dealer but you may have to get them ordered since they are only used on 1G's.
If you have a caliper you could measure the diameter of hole and depth. I'll look in the garage tomorrow and see if I have anything that fits for the thread pitch.
