98 GST Crossmember Motor Mount Bolt Size?
DrunkMcThief
45
Jan 29, 2007
Phoenix, Arizona
i just recently got this car and noticed the motor mount bolt is missing.
its from the mount on the cross member.
does any one know the size of this bolt so i can replace it.. thanks in advance.
Your description isn't exactly clear. There are 3 different bolts that pertain to the particular motor mount you mentioned: 1) two that bolt the mount roll stopper to the cross member; 2) one that connects the roll stopper bracket to the roll stopper; 3) two which bolt the roll stopper bracket to the (in case of a 2G) transmission.
1) M10 x 1.25mm pitch x 30mm long
2) M10 x 1.25mm pitch x 75mm long
3) M12 x 1.25mm pitch x either 28mm or 30mm long.
There are two different bolts listed for that particular mount on a 1G, either should work as they only differ in length.
M10 x 1.25mm pitch x 75mm long or 80mm long.
Bringing this up from the dead because I just found my rear mount bolt stuck between the cross-member and firewall.
For the rear mount itself, there are actually 3 bolts mounting it on the cross-member.
Would like to confirm that there are only 2 bolts mounting the mount bracket to the transmission itself. Because it looks like is the possibility of 3 bolt holes places... would just like to confirm one is not missing in my case.
I will definitely have to replace the bolts which runs through the mount itself as it is striped.
To be clear, the information given in post #2 is for the front mount.
Correct.
There are three bolts connecting the rear bracket to the transmission; they are all the same size.
Any know the size of the bolts that hold the mount bracket on the transmission for the rear mount? I was trying to remove one yesterday to find out, but it's really stuck on there... soak with PB blaster so we'll see. I definitely need to find a replacement for the missing tranny bracket bolt though!
