motor idles at 2000. question about blocking of vac lines.
LOL. yes. sorry about that. Is it necessary to have the block off plate? or is it ok to have the vacuum lines blocked off alone? The car idled at 1200 at first with the egr valve, theremostat, and 2 throttle body lines blocked off. But it rises to 2000 after awhile. I let it sit for a few minutes and I couldnt get the idle down.
This is right after a rebuild and letting the motor sit for awhile. only about 20 miles on the rebuilt motor so far. oil pressure and everything is great. just idling at 2000 is this normal when the motor is warm for it to idle at 2000? It idled at 1200 at start then warmed up to 2000.
You might check the choke sensor on the TB. I had this same problem on a Camaro recently and the electronic choke was not working properly causing it to idle faster as it warmed up to about 2,000 rpm and run rich.
DSMs don't have a choke circuit . They're fuel injected. ROFL
Boost leak test your entire system. Eliminate unnecessary vacuum lines aswell.
While your at it, test your ISC motor (Idle Speed Control). You should be able to find a lot of this information at VFAQ or that search button aswell.
But yeah just make sure everything is secure and ready to handle pressure.
ok. Sounds good. Im wanting to know, is there another vacuum line that i need to eliminate? the throttle body only needs the P. right? Could that cause it, because I eliminated the egr vavle and the thermostat lines. I didnt block off the actual thermostat ones because one plastic piece is broken off. do I need to block that off? I just took the vacuum lines off and blocked the other end. I hope that is fine is it? Also the motor has just been rebuild maybe it needs time? idk.
Why dont you hook up the two water lines to the FAIV and see if your problem goes away.
With out hot watter running through it the valve stays open reseing the idle as the rest of the enging warms up.
ok, I just read on vfaq about the ISC and the throttle position sensor. During the rebuild I took the throttle body and intake manifold and threw it in a hot tank. I did take the throttle position sensor off, maybe it needs to be adjusted again? maybe the ISC went bad from it getting washed.
What does the FAIV do?
OK DSM101 the FAIV is (fast air idle valve) there are two aprox3/8" fittings on the TB they go to the FAIV. Inside (not scrvceable) is a wax pellet when cold the pellet opens a valve valve letting more air into the intake past the throttle plate to increase the engine speed when cold. When the engine warms up the pellet expands closing off the air passage and dropping the idle back down to warm speed (aprox750/800 RPMs).
If the lines are not connected the pellet never gets warm/or takes forever and hence high idle.
The only thing plastic I see around the valve is the ICS that is on the same unit just to the left side of the FAIV.
Not having a 49stater I would have no idea what T fitting you are talking about.
  • For sale 1g Used 1991 Turbo Engine Control Harness, Auto, with ABS
    Used engine control harness for a 1G turbo, automatic with ABS vehicle, replaced any broken...
    • 19Eclipse90
  • For sale '90 Laser turbo
    115,000 miles. Bought new, lovingly cared for. Very low miles in recent years, mostly in storage...
    • GregPLT
  • For sale 2g factory torque converter
    2g Auto GSX factory torque converter
    • pottersgst
  • For sale JFH REAR
    JFH Auto LSD REAR
    • pottersgst
  • For sale 420A OEM 2G DSM 420a Fuel Injector Wire Harness
    $15 + shipping/fees PayPal, Zelle, Venmo, Apple pay
    • Stizzydrew
