idles 1500-2000
rspro
68
May 2, 2003
vb, Virginia
:( hi, on my 96rs it idles on 1500 when completely stop. But the weird part is when moving and then in neutral it suddenly shoots up to 2000rpm, until coming to a complete stop, then drops to 1500. I have cleaned the isc and check for vac. leaks, and still the same. The CEL is on and did the count. 12,25,31,21,55. I know 25 has to do with isc, but I don't know 21 and 31 are? Any suggestions? :(
I got the exact same problem ... mine shot a TPS code.
Do 2gnt's have fiav in the throttle body? if they do check yours, as my car did similar things when mine went bad
I replace my upsteam 02 sensor on Sunday, and I ordered my icm too. It still idles high but the only code it's showing is 25 (icm?). It will be here on wed. I keep you guys posted.
:( Hey guys, I just installed the icm and no luck it's still up at about 2k, and when I cruise in neutral it's up to 3k until I stop and drops back to 2k. Do I have to reset this thing or something? I bought the icm from advance autoparts for about $52. Please help..... oh by the way when I'm stuck in traffic with it idling so high the temp gauge goes up and I have turn the heat on? :(
Oh, I forgot to tell you guys that there is a whisling noise when I'm on the accelerator.
did u replace your isc? check the throttle cable for looseness? spray some lubricant on the throttle cable? adjust the biss screw? try those, and post back here.
I did replace the icm and I'm also replacing the tps but I'm waiting for the throttle body gasket to come in tomorow.
    • 4g63tv
    • 4g63tv
  • For sale 2g 99 2G parts
