dsmchop
- 0
- Jun 3, 2015
Warsaw,
Indiana
Hello all! So I have a 99 Eclipse GST, was running pretty good besides an exhaust leak. Long story short my MBC got figured on by someone that didn't know what they where doing. (I know I should have had it marked incase this ever happened
) But instead of 20 psi it pushed 30 and I shut it down. Well when heading back home there was a knock in the 2k-2.4k rpm range. Figured lifter, but then my thermostat went out and she got a bit hot a couple of times. (Found a coolant line spewing, fixed, turned out it burst do to thermostat seize) anyway got that fixed and was driving it home after work couple of days later and went to take off from the stop light and she stuttered real bad and died, thought I herd metal crash. So now Im wondering if I should buy a new motor, Im thinking of using KarKing, they have a reman for 1800 bucks... but Im not sure what that all comes with.. It doesn't show valve covers in the pics... Or should I have a shop rebuild or what?? Im looking for the cheapest best option.. Im trying to stay away from buying used because I don't want someone else's problems
. But I don't know what king of condition my block and head are in so I don't know how much a rebuild would be, who knows what kind of machining needs done?
any advice is appreciated!!
The motor at karking:
http://www.karking.com/index.php/re...-eclipse-2-0l-4g63-dohc-7bolt-turbo-engi.html
anyone know what this comes with? obviously not the turbo, but what about the water pump and ect???
Anyone got a 7 bolt engine for sale?
Thanks guys, not just for this but all the info ive gathered over the past year from this forum its like a dsm encyclopedia
. But I don't know what king of condition my block and head are in so I don't know how much a rebuild would be, who knows what kind of machining needs done?any advice is appreciated!!
