caseyk
- 206
- 4
- Jul 17, 2008
Anderson,
Indiana
So lastnight I made hard lower intercooler pipe to fix the rigged up pipe I had for the 14b for temp. Drove the car and ran great. Later through the night I put a couple gallons of race fuel in. Drove good, then I did a pull. I blew a coupler off the lower intercooler pipe. I limped it to a parkin lot and fixed it. Ran good again. Then out of nowhere it starts to miss and run on 2 cylinders it sounds like. So I pulled over and the car is smoking like a frieght train. It was horrible. I got the misfire to go away and it drove fine. Then it started to miss and smoke yet again. So I took the terminal off the battery for 10 minutes and put it back on. It ran fine so I took it home and parked it. Woke up this morning and drove it. It ran perfect. I put it in neutral and revved it and out of nowhere it started to miss horribly and smoke. So I revved it up again then the miss went away. After a few revs my car billows out smoke like crazy. But let it idle and drive it it dont smoke.
Im so lost of whats going on. All couplers are on tight. Intake is on turbo good.
I'm not sure if its the race fuel thats messing with it or not. Car ran fine before I put it in.
I've ran race fuel through the car before and had no problems what so ever.
