missing
totaleclipse3
68
Jul 29, 2005
Deland, Florida
a friend of mine took my car to get cleaned and they sprayed water directly into my engine, when i got into the car to take off it was missing and running really ruff, so i pulled over and let the car sit for a sec, when i pulled back out it didn't do it as bad, but still did it under hi acceleration, i changed the plugs and wires and it worked for a day or so then started over again. I don't know what it can be, any ideas???
First at all seem that you are venting. (are you?)
Also seem that the issue is water on the system. but should be gone by now.
does the car Idle? Which spark plugs? NGK BPR6ES or 7ES? More details please....
Did you check for Boost Leak?
When you say, "they sprayed water directly into my engine", what EXACTLY do you mean? How did the plugs look when you pulled them? Have you had any CELs since you began having problems? If so what codes did you get from them?
