YellowTSI
- 0
- Aug 7, 2004
Queens,
New York
Hi. I just did 6bolt swap, rebuild bottom ported and polish head oversize valves ,FMIC ,big 16G 3' O2 housing ,3' downpipe with exhaust fuel pressure regulator, etc ( I am not trying to imprest nobody just so you have idea what was change on the car ). My problem is idle -verry bad, it will idle 300 - 800 and stall. When it gets worm the RPM are 1200 - 1600. So I decide to adjust the BISS ( I have 1G N/T throtle body ) and that's when I realize that I am missing that plastic screw. Instead the hole it is fill with something like wax or clay only harder. My questions:
1. Should I dig all that stuff out and replace with BISS screw ? Would that solve my idle problem ?
2. What would be next ?
One more thing... When I drive and press clutch or put on neutral my RPMs droping really slow. Please help.
I have DSMLink but I didn't play with it yet. Thanx for any help
