2g SAS/BISS Question - SAS screw missing! :)
jarodrm5
Jan 26, 2008
a, Kansas
I have a question about the SAS screw behind the throttle body. I've been trying to track down some occasional idle problems that I've been having(dropping 2-400 at stop lights, vibrations in cabin, etc), so I've been looking around my engine. My idle is usually anywhere between 500-1000, dropping lower when i brake soon after starting the car. I've replaced my vacuum lines, checked for leaks, etc, but I actually just noticed that my SAS screw is completely missing! :cry:
Any ideas what, if anything, my car would/wouldn't be doing without this screw? Any chances this could be related to my occasional idle problems? I looked at the 2G BISS adjustment FAQ and I noticed the SAS was mentioned, so I figured it may be related. I don't always have idle problems, but they are frequent enough to be annoying. Thanks!
Also, if it is necessary, is there any idea what size/type of screw/bolt it is? Something I could hopefully pick up at a hardware store. :)
Some additional information if needed - I had these problems before today, but today I replaced the plugs with 4x NGK BPR6ES as well as Accel wires. I also did a Seafoam treatment through the TB (yes, before I changed the plugs) :) These seemed to help a bit, but its still there intermittently.
I went ahead and adjusted it up to a pretty steady 1000 - I'm going to see if that solves the problem. How long, if at all, does it take to recognize that I have been fiddling with the idle and adjust it back? This is on a 2G. Still strikes me as very weird that my SAS screw is just not there. Thanks!
I actually have the BISS screw, its the SAS screw behind the throttle body that I am missing. I adjusted my idle via the BISS screw this morning, and it seems to have helped it out, so lets hope that was all it needed. Thanks!
