solarhog
- 1
- Jun 20, 2002
Medina,
Ohio
The question I have is that I just installed a Reman T/B its Larger than stock,
After I Installed I reboost checked and No leaks. Now since this was a shell I had
to Install the sas screw and my Old Tps.
I performed the sas adjustment in Service manual Turned all the way out
and Turned in 1 1/4 turns then adjusted the cable, Then I adjusted the TPS
with the Feeler gauge and Meter. The problem Im having with that screw only 1 1/4 turns in Its hunting to stay running when I turn the screw in more the idle smooths out
but in turn screws up Tps adjustment. That 1 1/4 turn seems to not enough to me when comparing to old T/B. Any one else experience this problem?
