Missing rear engine mount bolt
I cant seem to find out where to buy this rear engine mount bolt nor can I find out any information about it. Can anyone tell me what size it is so I can maybe go to a hardware store?
Yea.
You should put it on the wnt.
I'm going to go to the Yank yard in two days,
If you can't find it before, PM me.
Rear mount isn't threaded is it? I dont think it is. Just pull the front roll stop bolt out, take it to Advance Auto, have them find a grade 8 or higher bolt the same diameter, length, and get a matching nut/crush washer.
I went to my local hardware store and I couldn't find the bolt, There was only two sizes iI found m10x1.25x100 and m10x1.25x120. I wasn't sure if they would work or not because the threads aren't very long but I am starting to think I'm going to have to call mitsubishi....
Easy solution is getting one from a junkyard for cheap! I know i have a extra set of mount bolts/nuts laying around if i can find where i put them the rear is all yours.
