Please Support Kiggly Racing
90 Eclipse GSX
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Turbo Type
16g
Build Type
  1. Street
  2. Drag Race
Walbro 255LPH,
FIC 750cc Injectors,
Fuel Lab Adjustable Fuel Pressure Regulator,
Fuel Lab Fuel Filter and -6AN Feed Lines
ETS Short Route Front Mount Intercooler Kit
3" Turbo Back Exhuast,
Halmen Boost Controler set at 21psi
PR o2 housing with 38mm Tial External Wastegate
50mm Tial Q BOV
Ebay 16g
Dejon tools 2.5" Intake
Ported Forced Performance Exhaust Manifold
FP Manifold Blanket
Silicone Radiator Hose kit
CX Racing Alumunium Radiator
EGR block off
Cruise-Control Delete
AC Delete
JM FAB Catch Can
Avid Racing 75A Engine Mounts
Mods-Engine
Balance Shaft Eliminator kit
ARP Head Stud
Mods-EMS & Logging
AEM Wideband,
Oil Pressure Gauge,
Boost Gauge
Turbo Timer
DSMLINK V3 Speed Density
Mods-Drivetrain
4 bolt rear end swap,
English Racing Transmission
Act 2100 Clutch
OEM Flywheel
Slave/Master Cylinder
stainless clutch line From Master to Slave
Solid Shifter Base Bushings
Solid Shifter linkage Bushings (skateboard bearings)
Evo 8 Enki Rims
Parts Wishlist
Magnus Intake Manifold, FP Green or Black, New engine, Act 2600,
Dyno HP
305.9 whp
282.64 lb/ft
Dyno Type
DynoJet
Dyno Sheet Photo Link
Dyno Shop Name
English Racing
Dyno Session Details
21PSI Max Pump Gas
bradcurtis15
More in 1G DSM
Share this Vehicle
