misfire or fuel cut?
I believe it is the shitty as CAS plug. All 4 wires are cracked and exposed at the pigtail and the retainer clip isn't there of course. I had a cel and I ####ed with the wire and pigtail and it went away and the car started to behave normal again. Bov is shitty greddy knock off and is recirculated. I have a p.o.s. narrow band. This isn't my first DSM, I just happen to go to MSU now and I can't give her the attention she needs. I've fixed many many problems on her and she has almost 0 leaks and great compression. I need to order the CAS off jnztuning and possibly find a known good throttle body bc mine came rtv'd to hell.
are you hanging in your seat belt while it pops? Fuel cut is a safety mechanism cutting the fuel if the engine consumes too much air resulting either in too high boost or rpm. So thats not the case.
With your tongue: Is the shid fuccin CAS the damn freakin problem or is it the monster shid pigtail of that CAS bitsh?
Very hard to use so many swear words - maybe we both could just leave them out xD
