2G misfire in cylinders 1 and 3
zcoh2gdsm
646
4
May 13, 2011
harrisburg, Pennsylvania
not sure whats wrong, only started happening when i put the car back to stock. i replaced all the plugs and gapped them to .28 however it made no difference, i know its cylinders 1 and 3 cause when i pulled the plug wires it made no difference. i didn't see any arcing in the wires, any idea why it would randomly start doing this after i put it back to stock?
I would say coil or power transistor. Since you were messing around under the hood make sure your power transistor is plugged all the way in.
i was just thinking the power transistor also, it would make sense because it's only those two not firing. i didn't touch the power transistor but i could understand if it needs replaced, the cars 15 years old so far everything else needed replaced.
Could be a coil pack is acting up, or injectors not firing.
all injectors are firing, its spark, making me think its the power transistor.
Just tried a new ECU and the misfire changed from 1 and 3 to 2 and 4. I'm stumped. I haven't done a BLT yet because I don't have a compressor right now but that's next on my list. I did see smoke coming from the front O2 sensor area also, I didn't see a crack but it was smoking from that spot.
steve, only parts I changed was putting the stock airbox back on, taking out the EPROM ECU and putting in the stock one, then taking out the wideband and boost gauge.
