6bolt952tone
- 0
- Apr 1, 2007
stockton,
California
fire in cylinders 1 and 4, no fire in 2 or 3. change coil pack... still have the same problem... change cam angle sensor... still have the same problem. Coil pack has power to all 4 points.. i think it might be a relay issue.. ??? not sure. checked all fuses... but im not to familier with checking relays so i havent had a chance to do that yet and also which relays to check in the first place? any help is greatly appreciated, thanks ahead of time!
Set up is a 6 bolt in a 95 eclipse.
