Misc Bolts Needed
clutchkid09GSX
Dec 23, 2011
Batavia, Ohio
Hello again. I know as soon as I get my motor for my 1992 Mitsubishi Eclipse GSX in. I now I will need an assortment of bolts. IE Subframe, transmission bellhousng, motor mounts, and other engine bay bolts. I was wondering if there is a grade A bolt kit I could get online or any other supply of grade A bolts.
Fastenal will sell you a lot of bolts. Meaning a bad of 25-50, and that changes based on size and so on. Thus the reason I suggest you make a list of what you need and go from there. I bought a bag of bolts that I used to replace my fenders with button top grade8 bolts instead of the stock 10mm ones. I bought them for another purpose at first, in a 1.5" bolt, then just slipped a die on em and cut them down to about 1/2in long and used em for body panels. It just depends on what you want, and how much your willing to spend. This car isnt exactly a SBC or something where you can call up summit and get a bolt dressup kit.
Some bolts are OEM specific and you can't just buy from a hardware store. Some bolts can't be duplicated and are specifically designed by Mitsubishi.
I would suggest going to a local junk yard and finding bolts off of engines there and the rest I would source from JNZ or Mitsubishi dealerships. A lot of sites have specific bolt kits for say water pumps, front cases, vc's and things of that nature.
i actually got like a 25lb assortment of various mitsubishi bolts right off ebay. cost me like $20 or something shipped and had a large variety of mitsu specific bolts etc. basically everything i needed at the time. may be worth your wild to check it out
Some bolts from hardware stores work i have a few on mine, but some i would get from the dealer, a lot of bolts will fit just about any setup i found the lengths are the problem in some cases.
