tintedglasses12
- 85
- 0
- Feb 24, 2009
Belfast,
PE, Canada
i got a 1992 plymouth Laser 2.0l turbo AWD 5speed. Im just looking to do some minor mods. So I was wondering if some would give me some tips
. But if i buy the Walbro 255 LPH does it come with a kit with everything i need. Wats a AFPR. im sorry for the questions im all new to this shitwell so far i have put new set of plugs, wires, and coil pack. K&N cold air, replaced timing belt and balance shaft belt. and i had to replace the rear pinion seal. she runs great actually, and i dont bag on it. So i dont know ### else to do, except to mod
Coil pack? please inlighten me. Because the stock coil pack will be good for 500+ HP
Maintain that vehicle first.
Boost gauge is the first thing
and some cheaper things like Upper intercooler pipes, Exhaust, and go for the 190lph fuel pump. The 255lph pump like everyone else said that your going to need a afpr but they are most of the time the same price.
Change the plugs NGK BPR6ES and some nice plug wires.
Fuel Filter (doubt its been changed)
change all the fluids, Trans (gl4 only), transfer case and rear end (gl5)
Change the coolant and oil.
Take the intake tube off the turbo and check the turbo for shaft play.
then its off to vfaq.com that site will show you the rest of your upgrade paths..
