- Thread starter
- #26
99gst_racer
Moderator
- 12,010
- 1,707
- Apr 5, 2003
Coloma,
Michigan
Make some room for me!
All I have is the back of a 2-car garage right now.
If only you were closer. I'd be honoredED... You are more than welcome to come clean around my machines!! OCD is welcome here!
The nice thing is I "THINK" you can use a 20% off coupon on the lathe.
So say you want to make a whole lot of bushings or something, can you set it up to be exact and make a lot of do you do it all my hand and having top and measure a lot?
Also say you wanted an offset hole can you do that on the lathe? Do you move the tailstock ?
If a bunch of us lived in the same town, I bet it would have already happened.Can you imagine having a couple of knowledgeable DSMers from this site opening up a shop??? Man, that'd be the perfect setup for good times and great products/work/support
Anyone want to?
One turbo just wouldn't have been enough.BTW Racer... I love that you did a twin turbo swap on your tool box!!
Great idea, but that wouldn't work for me most of the time. I primarily turn aluminum.A 2lb cylinder magnet with an aluminum sleeve works wonders for picking up metal shavings. Pull sleeve up, pick up shavings, slide sleeve down. Presto, shavings fall off and cleanup is done.
IIRC, I gave $399 for mine. It was on sale for $100 off and I was able to use some sort of 25% off coupon for ordering online.The nice thing is I "THINK" you can use a 20% off coupon on the lathe.
CNC would be a huge time saver for me. But I'd be happy enough with a DRO kit. They all had DRO's back when I learned in high school, and it sucks going without it now. I'd just have a hard time sinking a bunch of money into a small lathe, knowing that I already would like something larger sometime in the near future.
I'm really not sure. Probably around 20 minutes for the aluminum and another 10 for the steel part. I'd have to time myself to be sure though.So say one of those bushings you made on page 1, how long would just 1 half of the bushing take you?
Yup, 6061 extruded. Extruded is quite a bit cheaper than cold finish. That's where I order my aluminum too.And is that 6061 t6? I looked at some at onlinemetals.com and there are quite a few different kinds of 6061 t6 and expensive too!
Yup, they do make aftermarket chucks for just about any lathe. On larger lathes, the jaws of a 3-jaw chuck are pretty wide and will center a cylinder shape object very well. On a mini lathe like mine, the jaws are tiny and will allow the work to tighten up and be be up to .050" away from spinning true. So, I use a dial indicator and spin it slowly and tap it straight before I fully tighten it up. It usually only takes me like 10 seconds when I'm on a roll, so it's no big deal.Can you put a 4 jaw vice on this machine? And if you do when you tighten will it center itself or do you have to recenter it as well?
Like Wes said, it stands for digital read out. It basically tracks distances on all 3 axis. So you can zero out each one and easily keep track of where you're at on the screen. Without a question, my next lathe will have DRO. I could work twice as fast if I didn't have to stop and measure all the time.Edit: What's a dro?
I'm not even close, but I wish I was!If you are anywhere as close to being electrically enclined as you are mechanicly enclined here is an effective/inexpensive DRO for your lathe. I have seen it done where just a digital micrometer is used but without moving the readout it can get kind of awkward (small display/wierd angels).
USB DRO
I googled it and found this reply:Whats the difference between extruded and cold finish?
I've seen the micrometer ones, but never liked using 3 small screens like that. I suppose learning on a true DRO system has really spoiled me. And a real system is pretty expensive. Most of them cost more than the lathe itself, and it seems a bit silly to spend that for a cheap benchtop lathe.
I do like that USB system though. I have a junk laptop that I could use as well. I just wish I were electrically intelligent enough to be able to make that system work. This stuff is hyroglifics to me.
You'd just turn them from hex bar: Order Aluminum Hex Alloys 2011, 2024, 6061, 6262, 7075 in Small Quantities at OnlineMetals.comHow do you make your own AN fitting on a lathe? i've seen people do that, but don't get how you put the "flange" on it for lack of a better term where you put the wrench on it.
The HF lathe comes with two different sets of jaws. One set for small diameters and one for larger diameters. The contact area of the small diameter set measures at .650". These center the work up nicely. The contact area for the larger iameter jaws measures at .250". That set never centers up perfectly without using a dial indicator. The benefit to a larger lathe is that there is ony one set of jaws, and they always center the work great.My 3 jaw centers near perfect. Give this a try.
