Milling cylinder head
mechanix565
165
Apr 19, 2009
Pawtucket, Rhode Island
so after getting my head milled im trying to figure out how much compression ive gained if any
7 bolt head ported/polished and milled .015
block resurfaced .003 material removed
this gives me a total of .018 total removed height
im running evo 8 rods and pistons which with a stock dsm head nt a 8.3.1 compression ratio..
stock head gasket thickness is .050 and ill be running stock size head gasket
will I get a noticeable increase in compression id like to gain a bit what do you guys think
Were the combustion chambers polished?
Were the valve seats cut/ground? This sinks the valve and will open the combustion chamber.
With a .050 thick HG, that sounds like a Cometic. Or are you talking about non-compressed thickness? Most stock composite HG compress to .039
What is the piston to deck measurement?
With out given measurements and volumes.... there is no way of knowing what the CR is.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
