Cylinder head setup
SlowChild3
545
9
Aug 19, 2005
Dayton, Ohio
So I have 100,000 mile head. Im building a 2.3. Looking for 500hp+. I basically want to know what I should replace. As far as I know alot of the high dollar head components are to rev high. I do plan to get some cams in it. Depending on what part s I should replace will determine on brand of cams. Will the valves, locks, rollers, and guides be ok to reuse? How do I check the guides?
All you really need to do is replace the valve seals and resurface the head if your going to an MLS head gasket. Springs and retainers will depend on the cams you choose. To check the guides you need to pull the valves and see if any of the "tips" are cracked. (When I say tips, I mean the part of the valve guide you see after you removed the valve, if your looking at the combustion chamber side into the port). Everything is ok to reuse as long as it's in good working order. Have the head pressure tested also.
I am also building a 2.3 and after reading through many many threads and reading up on different brands and part. I decided to go with kigglies and kelford 272's. I used the ferrea +1 valves with new guides and seals from super tech
Ok. I've read things about valve height or spring height? Need shims to adjust? I can't find much info on how to measure and adjust. Anyone have a link?
So ill get valve job, resurface, springs, retainers, cams, gears, and pressure test. Already planned to get revised lifters. Are the gears worth the gain when doing cam degree?
