MHI TE06H-24v turbo
awdass
May 12, 2009
Rochester, Minnesota
I wanted to add to current turbo (MHI TE06H 24V) posts here and Im not able to do so because of my newbie status. Im trying to reference this post:
http://www.dsmtuners.com/forums/turbo-system-tech/322460-mhi-24v-compressor-wheel.html
Im a fan of the DSM community and used to own a 98 GSX. I figured I could give back to the car community because there is not much info on this turbo that I could find. I would like to add the information I have on it from just flat out using it to possibly help others.
Also if anyone has been able to find a compressor map of this turbo I would be interested in seeing that. Here is where I originally got this turbo.
TE06H 25g T25 turbocharger 550HP Anti Surge Compressor | eBay
Don't laugh I just made 600hp and 866 ft/lbs with this turbo. Not bragging. (There are way bigger hp cars on this forum than that)
[ame=http://www.youtube.com/watch?v=DBY7qcT1W1o]MMZ 4.3 Sy/Ty V6 E85 - YouTube[/ame]
Online it says the max HP for this turbo is between 475 and 550. They are pretty darn close to that. I could have made more power but the turbo could no longer support 24psi on that engine and tapered off to 22psi. A larger exhaust housing might help.
Here are the specs Im running with the 24V compressor wheel.
Turbine Housing A/R: 12cm^2 with T3 Flange
Turbine Wheel Exducer / Inducer: 55.8 mm / 66.3 mm
Compressor Wheel Inducer / Exducer: 55.5 mm / 77.9 mm
Flow Rate: 800 CMF @ 1.0 Bar
Final conclusion is the TE06H 24V a very cheap turbo that seems to have great durability and packs a punch.
