MBC/Boost gauge issues
Kyser
124
Dec 11, 2001
Milwaukee, Wisconsin
Ok, besides messing with my slave cylinder this last few days or so I have started to install an Autometer Ultralight boost gauge. My car came with a MBC so I didnt think I needed to worry bout that but now Im not to sure since things just arent working right. Anyhow Ive wired up my Boost gauge except the power source for light and have been testing it with not so pleasant results. I have been following this install guide http://www.jumptronix.com/2g_go_fas...ostGaugeFAQ.htm and thought I had everything hooked up right. Anyhow we originally installed it and tried to test the car at different boost levels. No matter what I did with the MBC the boost never really moved. It went as low as like 9 and as high as like 12 with a few very brief spikes to 13-14. So I did some more searching and came up with this:
attachment.php
He had it hooked up a bit differently with the wire that supposed to be T'd into the BOV/Intake vac line instead was going to the Lower intercooler pipe. So today I changed that, T'd the line into the BOV/Intake vac line and put a piece of vac line between the Lower Intercooler pipe and Intake(when I plugged the LICP like someone suggested in an earlier post the car sputtered and died everytime I tried to start it). I figured ok now everything is set mess with the MBC a bit and absolutly nothing has changed. So I took some pics and looking to you guys for help.
Also hitting the gas in nuetral will still give me accurate boost level readings correct or do I have to be moving. Im very new to the turbo world so Im learning as I go.
Without further ado here are the pictures of my engine bay that I hope will help you guys help me.
~Lyle
Well that makes a differance now doesnt it, well guess I get to wait till later to see if its all running right then since I still need to figure out how to make the brake fluid line fit into the new slave cylinder(the slave cylinder I got move the one line to a new location and it just doesnt seem to fit, its damn close so I will just have to mess with it later when my bro gets home from work)
Also did we get the right vacuum line to get correct readings for the Boost Gauge and does everything else look right in the pictures.
Thanks
Lyle
Hrm, they show up fine on my computer, and it wont let me attach the 2 pics I want, grrr.
Guess im stuck waiting till Im done with school and have a chance to finish the slave cylinder install
~Lyle
