Manual to auto. Wiring problem
heathcliff
Apr 14, 2013
crittenden, Kentucky
I went from 5 speed fwd to awd auto
I know the car is not wired for the auto. I have a light and od switch on the shifter. That seems simple. We're dies the od wires go. = 3
Now there's 2 plugs on top of trans. One there was a plug for it. The other?
I know the 1 pin plug on front is the temp. Weres it go.
There is a 2 pin near it???
Car will not go in reverse. Goes in drive and pulls feels to me like a high gear. Idk I need the car back on the road.
Resolved went out anf got a auto trans engine harness and tcm
Now new problem. Shouldbbe simple. Car won't start. If ibjump a wire to small startwr wire fires right up and stays running. Is it clutch switch? What do I do with it?
It's either the clutch switch or you still have the "other tranny" starter relay and/or harness on it (MT starter relay works opposite AT one). Just remove the starter relay and permanently connect (solder) the black/red to the black/yellow.
