MAFT with this type of UICP
SuzukiRidr326
171
Jul 15, 2007
Gardners, Pennsylvania
hey gys im in the market for a MAFT and i already have the 3" GM Mas, but i have this type of piping, can i still use a GM MAS with this or would i need to buy a whole new IC kit
THanks,
Jon B
You will need piping that fits the gm maft. Look at some engine bays of the 2g and that will give you some ideas.
You will have some serious cutting a fitting to do. You have to cut that nice dejon uicp. But out a 4 in section and get reducing couplers.. I would try selling that and buy one made for it from dejon
yes sell it then buy a kit to fit... i tried making a kit work and i have had boost leak problems like crazy
you can cut your pipe to make it work. some reducing couplers will do the trick. just make sure you measure/cut correctly. yes there is the possibility of boost leaks but that is going to be true with any MAFT setup. emclink SD coming soon!!
I would rather recommend you sell those existing pipes and get dejon's blow-through pipe kit or custom-make one.
