DROOPY209
- 493
- 4
- Jun 23, 2004
NorCal,
California
Ok guys. Today I installed my GM Maf-T translator and Dejon tool UICP for blow thru.
I disconnected the battery, replaced the BISS o ring, replaced both throttle body gaskets, and fuel filter all with OEM stuff.
I installed it all, and plugged the battery back on.
The car would not idle for the life of it. The rpms would float around 450-500, and it would eventually die. I had my logger hooked up and then I grounded the pin by the battery to adjust the idle. I would adjust the BISS screw but nothing would happen. The ISC motor is new and I can hear it working.
Everything is plugged in. No vacuum lines are disconnected. Everything else is good, the logger is reading everything just fine, fuel trims are at 100%
Yesterday I installed a new Bosch oem like O2 sensor and passed the emmisions test. The o2 sensor was cycling fine yesterday.
Today, after hooking everything back up, the 02 sensor doesnt cycle at idle. If I rev it up, and then let go of the throttle, the O2 will go to .89, then go back down to .00 or .01 and stay like that. Even if I give I hold it at, the O2 sensor wont cycle.
The car wants to die, and after a few seconds of idling on its own at really low rpm's, it dies. It stutters and stumbbles and when its about to die, the boost gauge goes up to about -5 Hg. It smells like gas, and my EGT gauge floats around 450-500 Celcius at 450 rpms. Timing is at 5*.
Is there a wire for the O2 sensor that maybe got disconnected or something?
