General MAFT Pro
Dred
187
Apr 20, 2005
toronto,
I've looked allover the fullthrottle forums, the manuals, and searched here, I dont find anything about larger injector compensation w/ the MAFT Pro. Even the manual doesn't go over the option of compensating for larger injectors. Can someone confirm whether or not maft pro allows to run larger injectors w/o tuning for it?
I suppose it does not then. But I mean, how could they forget, I was going to get MAFTPro before I'll get an EPROM but I already have 550 injectors waiting to get installed. Weird is all I can say how they could have overlooked that, if indeed they did.
is the PRO different from just the regular v2.01 maf translator? If its not then the instructions for the injector compensation are at the end of the instruction manual. Using a combination of the Base and Aux knobs you select the injector size. If the maf Pro is different than the maf translator i have then just forget i said anything. The full throttle website isn't working for me right now. When it works again i'll link you to the instruction manual incase you were looking at the wrong one.
Yes, it's a TOTALLY separate deal. I know you can run larger injectors using the system but dunno about just throwing them in there without tuning for it. I know you're suppose to adjust the mainscale and your Lo, Mid, and High loads. I'm just not sure if you'd start out at 0 and go from there or if you're suppose to set it to a certain area ahead of time. I'm running 1000cc injectors in speed density. Just tried to fire it up today but not sure if my ecu is giving me problems or what. As soon as I can fire it up and figure it out more, I'll post back and let ya know.
    • Sdcryan1
