MAFT basic setup
GnArKiLL70
72
Dec 20, 2007
aberdeen, South Dakota
i got a used maft with no intsructions, so how would i set it for 650 injectors 3" gm maf and suporting mods, also now it idles realy high what should i set the idle to on the translator?
Do you have the newer MAFT (with the digital control panel), or the old school one with the knobs within a small black box? If you have the older one, I've found a PDF file of the actual manual since I managed to have mine accidentally catch fire when welding too close to it.
Just ask, and I'll look for it, and upload it here. Its only a couple page PDF, so figure the file would be small.
yea its the older style with the knobs. that would probly help alot if you could post that...
also what wire do i tap into on the CAS for the rpm wire?
