1G MAF Translator wiring?
irishgangsta55
41
Dec 12, 2003
hanover park, Illinois
Does Anyone know where I hook up the white wire and purple wire to, on a 92 awd talon with the maf translator I lost my directions and I couldn't find a place online to explain it well enough.
Thanks for any insite you guys can provide.
The white wire gets hooked up to a clean rpm signal. I hooked mine up to the thinner black wire on the CAS. The pruple wire i beleive is for nitrous and other types of add-ons.
So the black wire is the rpm signal some one else told me it was the whiteish/ yellow on the cas, and I wasnt sure so I decided to ask thanks a lot.
Thanks again for your help.
Here is the Manual. I know it doesn't explain about where to tap the white wire in the 1G. I tought you might wanted to see it....
You might be able to tap it from the Power Transistor located by the coil (follow the sparks plugs wires). you can always run a wire from the ECU. here is the pin out
Also, the CAS by reading this (scroll dow to page 7) It say that the yellow one is crank signal = RPM....
but not sure wich one, when you know post it here. I am interested in knowing that....
I ended up connecting it to my cas but I have 2 black wires I did the thinner one and it worked great so far.
yes its the smaller black wire on your CAS. Mine works fine. The purple is for a remote NOS trigger. I thought it was power...but it didnt do anything so I took it off from my power supply.
