MAF translator or safc
zrk666
144
May 13, 2004
louisville, Kentucky
just wondering if the MAF translator is better or equal to a Apexi Super air fuel controller?
can they do he same thing?
They pretty much have the same outcome.
This has been discussed A LOT but..
My personal opinion is that as a first gen you should lean toward the MAFT because the 1st gen tends up upgrade the MAS sooner then the 2nd gen. One more thing about the MAFT set up is you can vent if you are into that stuff. S-AFC alone wont let you do that.
An AFC will be more accutrate then the MAFT becasue it adjust in smaller increments, buit like it has already been said the stock 1G MAF is a big restriction. I would use both the tune with. The MAFT to get you close and the AFC to get you dead on.
You WILL also NEED a logger if yuo plan on changeing ANYTHING.
  • For sale 1g 1G AWD Fuel Filler Neck
    1G AWD Fuel Filler Neck $75 + shipping & paypal fees* I would replace the rubber elbowYou...
  • For sale 1g 1G 4 Bolt LSD Rear Axle Set
    1G 4 Bolt LSD Axle Set $120 + shipping & paypal feesYou must be registered to see...
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
