Maf translator no working is it broke?
white90gsx
674
Dec 21, 2006
Wilburton, Pennsylvania
I did some searching and did not get a complete answer. I don't know if the tuning knobs are wrong in the translator or what. It runs just like when you unplug the stock maf sensor and there's no lights on on the translator any suggestions?
I bought it 2nd hand.
My car doesn't run when I have the translator and the mass air flow hooked up its running just like you unhook the factory sensor it hesitates and stumbles then the car dies.I dont know if its the settings on the translator or what?
Verify your connections then watch for the LEDs that are supposed to indicate function.
Im not getting any lights.
Okaaay, did you verify your connections? I had previously read your post about the lack of LED activity, thus the suggestion to...you guessed it...verify the connections. ;)
there all connected and nothing
I'm completely lost here I think I should get my money back what do you guys think?
Take off the connector and check to make sure all or some the pins are not pushed back in the socket, It did that to me cause the factory harness part was a pain to plug in.
Make sure you have a working MAS too...
I tried that and nothing I also found burn marks on the board so im going to get my money back.
isn't it frustrating. Same thing with mine
