MAF/MAS Questions
n00btalon
197
Aug 13, 2005
lebanon, Pennsylvania
I haven't decided on which one I'm going to go with, the 2g (609's) or a 3g?evo? 399 or 482... i also found a good deal with a pipe and a 338 mas on the classified but I'm not sure which that is? In searching all I found was its a N/A 3000gt mas? correct? (then would that work on a turbo?)
so what would you suggest?
A good deal (2g w/ pipe) or an EVO (482)?
or this 338 mas w/ pipe?
yeaaah as the guys said before ,go with a 2g mas setup.Its proven by alot of 1g dsmers and just work great Also big hp numbers are proven with 2g mas.But if you really want to go bigger.I'd recommend going gm maf setup ;)
