turboglenn
- 6,375
- 123
- Nov 5, 2007
RIpley,
West Virginia
Well, i was bored tonight and made this ( took a late nap today
) anyway, the only thing left to do is turn the "cap" to match the OD of the rest of the unit. But noe i'm trying to figure out if i want to use it for the catch can for my PCV setup (already have several though and one 'm using for the vent line as well)
I love the way it came out (for being done at 4am especially
Anyway... YOu've probably all seen my "box" type catch cans..should i use 2 of those for the venting and PCV and use this as the coolant overflow, or just make this another catch can for the PCV system ( i'mhaving 2 cans...one as the "vent" that will draw suction from the filter to tubo tube, then the one i am still working on has a functional PCV inside -6 line and all i need to do is come up with the vacum source for it and put a male -6 fitting on whatever can i'm going to use... I'm using push to lock for all the vacume related connections, and -AN stuff on the actual oil passage tubes and everywhere else i can.. I love AN fittings and SS braided hose
So tell me what you think...also it will be pollished before it's installed on the car... it's ust the way i am with aluminum (but i'm not doing another valve cover
) The VC will be painted or powder coated and then have the "mitsubishi" and "DOHC" polished up as well, or at least sanded to make it shiny like they come factory
HEre's afew pics...also there's one showing the current can to be used as th vent with the new can next to it for comparison.it will hook to the -6 that's next to the -8 for the vent and will become the PCV
Here's a pic with a -6 fitting and a 1/8npt push-to-lock fitting like used on pneumatis and alky injection systems... the push to lock will go to the manifold for the vacume source. Then the -6 line will go to the VC with a PCV valve in it so it functions correctly.
By not having any "open vents" I'm hoping to keep enough negative pressure in the cans to eliminate any excess crank pressure. Btu ihaven't blown any oil on the new motor anyway, but i want to keep it thatway
BUT...there's stil the thoughts of making it the coolant catch
confused is my second middle name
) anyway, the only thing left to do is turn the "cap" to match the OD of the rest of the unit. But noe i'm trying to figure out if i want to use it for the catch can for my PCV setup (already have several though and one 'm using for the vent line as well)I love the way it came out (for being done at 4am especially
)Anyway... YOu've probably all seen my "box" type catch cans..should i use 2 of those for the venting and PCV and use this as the coolant overflow, or just make this another catch can for the PCV system ( i'mhaving 2 cans...one as the "vent" that will draw suction from the filter to tubo tube, then the one i am still working on has a functional PCV inside -6 line and all i need to do is come up with the vacum source for it and put a male -6 fitting on whatever can i'm going to use... I'm using push to lock for all the vacume related connections, and -AN stuff on the actual oil passage tubes and everywhere else i can.. I love AN fittings and SS braided hose
) The VC will be painted or powder coated and then have the "mitsubishi" and "DOHC" polished up as well, or at least sanded to make it shiny like they come factoryHEre's afew pics...also there's one showing the current can to be used as th vent with the new can next to it for comparison.it will hook to the -6 that's next to the -8 for the vent and will become the PCV
