M12x1.5 to m12x1.25 ARP extended wheel studs
kidtsi
1,417
17
Feb 17, 2009
Laredo, Texas
Would this fit our 2gs? http://www.jegs.com/i/ARP/070/100-7716/10002/-1?parentProductId=747558
The kurl is the same .565 but i just want to make sure, if your asking why its because i got an unveliabebale deal on a set of Racing composite lugnuts which are $250+ and they are x1.25.
I know you guys are not familiar with this lugnuts but i have my reasons of why i want to put them on besides they don't damage the wheels when torquing them.
It should work if you have oem hub because the aftermarket hub assembly I had have a smaller kurl. I personally have switch to 1/2-20 studs with the same kurl because they were half the price in extended version compare to dsm extended studs. I also get benefit of thicker studs and cheaper\more lug nuts selection.
Yeah for $160 a set. The 1\2"-20 studs I bought was only $50 for a set of 20, I don't remember but it was for a Ford vehical.
well yeah but you don't have to worry about buying a set and them not fitting.. These are for our cars. But I do see where you're coming from. If the OP's choice do work, I'd pick them up myself.
Yeah i have the oem ones, the aftermarket one i believe are .489 or something close to that number.
They are the same thing "ARP" and in the first link they are cheaper and i said i cant use x1.5.
Don't mean to bring this back, but did the Jegg's studs work for you? Did you go with a different set?
they worked, I make sure all the bearings where oem with .565 curl. I bought the 12x 1.25 from a Subaru since my lugnuts where 12x1.25 Kicks racing composite r4o's, it was a pain in the ass to put them on though i had to remove the wheels bearings on the back, i went ahead and replace my front and rear rotors with brembo drilled replacement.
I'll post pics right now.
Thanks for writing back. I've been waiting awhile. LOL
I do have stock OEM bearings and D/S Rotors from Stoptech so I'll go ahead and get some.
Thanks, man.
ARP elongated studs 12x1.25 $135 from jegs
Racing composite lug nuts $275
Sorry for the dirty car and crappy pictures but here they are...
Thanks, man.
LOL Sorry bro it took me like 36 hours to do these. :sosad: Make sure you remove the old studs with some useless stock lug nuts you have laying around and hit the with a big hammer, also Make sure you press them in by using a lug nut and washer and not hitting the in...
I have a huge box full of useless lug nuts. Figured they'd come in handy sometime soon! :p
What wheel/tire setup are you using? Rfp1's with what tire? Was any spacer being used? Sorry if I missed any of that info in the post, man. :D
