gsxitement
- 1,967
- 1,944
- Dec 9, 2002
DOBBS FERRY,
New York
Just thought I would throw this warning out there for folks who may be doing this as per the new rules going around that you need to have extended studs to race. If you have aftermarket hubs in the front or rear, if they're not mitsu, you're gonna have a hard time. I have some aftermarket hubs in the front, and the shoulder part of the stud, the part that actually gets pressed into the wheel flange is smaller than the ARP's. You'll have to ream the stud holes to make the longer ones fit. You'll also have to grind some of the spindle to get the stud to fit in without damaging the threads. Just a heads up. The rears were just fine, but you have to remove the hub from the car to get the new studs in. Hope this helps.
