lower ic pipe leaking
darkstar5456
207
Feb 23, 2010
Mitchell, South Dakota
ok so i might be wrong. but for some reason my lower ic pipe is leaking coolant.its the stock rubber hose and if i put preesure on it flows more so i need some help. been trying to fix the leaks. on it so any help. would be thanks
There's a good chance your turbo is leaking coolant into your intake system (lower IC pipe). As long as you stop driving the car ASAP, you may be lucky enough to simply swap in a good turbo or get your broken turbo rebuilt; this is assuming there isn't any engine damage due to the coolant getting into places it shouldn't.
If you absolutely have to drive, drive the car super easy; I wouldn't drive it however, until getting it figured out.
Is your inner-cooler full of coolant? -- and I hope you're talking about your lower IC pipe and not your lower radiator hose, because these are obviously two completely different situations. :ohdamn:
Any strange driving conditions; does the engine run funny?
as far as i can tell no there isnt any in there it might be one off my water line hoses was to short and who ever put it on just cut it at a slant and strecthed as far as it could. so i am hoping that is the case and the coolant is just falling on the lower ic and it aborbsing it. as it is still the stock on there.:pray:
Clean the pipe and look for where it's coming from. If you had coolant leaking into the IC pipe through the turbo the. It would be in your oil unless it's leaking from the outside and dripping in though a coupler/clamp.
Get a new coolant hose where you cut it short as well just to be safe if it is t the problem.
update found the problem its is my lower rad hose and it was driping on my lower ic pipe so the hose was absorbing it and dripping itself. havent change the hose yet so i can say its the problem but i will report when i do as it had a trail of coolant all the way up to the thermosat neck. so wish me lucks guys hope this is the problem and not somthing bigger thanks:pray:
update its was my lower rad hose. it was leaking at the neck of the hose by the thermostat.changed the hose with a new one and bam no leaks thank god. thanks for the advice and help though guys much thanked:thumb:
