low speed hearing metal spinning noise from back wheel?
tigglebitties
80
May 18, 2005
Apple Valley, Minnesota
So when I'm cruising going kinda slow 20mphish I can hear kind of a spinning light metally noise what would be the cause of this? I have stock rims too if anyone is wondering.
Could be a few things.
The brake dust shield was already mentioned. You can't miss it it is right next to the rotor on the car side (as opposed to the wheel side). Just bend that bad boy back into place with your hand. Had to do that after changing brakes and wheels. Guess I bent it during the process. I had to bend the lower right portion away from the rotor.
I had a sound like I was dragging chains that happened to be a bolt on the knuckle worked its way loose and was rattling around. Wouldn't hurt to check the bolts, boots, and cv joints while your under there.
Could also be your wheel bearings. Let's hope not
Let us know what you find out.
Mine is making that sound too. It sounds like its coming from the brakes. I checked the wheel bearings by lifting the car up and moving the tire and no play so Im assuming bearings good. I didnt however, check behind the rotor. Ill have to do that next time.
My brakes already have a bad booster.
Are the pads aligned with the caliper piston correctly? There is a nipple on the piston that must align with the pad. My GST made the same noise, it was because the pad was uneven and wearing at an angle because the "smart guy" who had it before me obviously didn't know what he was doing?
    • Sdcryan1
