hearing noise
if it makes noise when you change gears then is not the struts. check the gear oil level on the transmission.
If you're not mechanically inclined, the best advice I can give you is for you to take it to a reputable shop that can do a free suspension inspection. Most common causes of "clunks" when going over bumps include: inner and outer tie rods ends, worn strut mount plates, worn shocks/struts, etc. If it's clunking when you're shifting, you may have a transmission mount that's deteriorating or some other issue.
The BEST way to get this identified is to take it somewhere for an inspection.
