Spinning noise from starter
when you install the starter you have to make sure it is aligned otherwise it wont engage. This happened when I put my Camaro back together, it would just spin because It wasn't bolted in correctly
There is only way way to put it in. I am afraid I got the wrong flywheel
I just found out that it was an AWD flywheel I got so it looks like I have to pull the tranny and switch it. Does anyone have a flywheel I can buy?
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
