Push clutch in...grinding "spinning" noise?
mokkema
46
Jun 1, 2005
Chitown, Illinois
Basically I was out last night, turned the stereo off and was in complete silence when I heard then that when I push my clutch in at a complete stop....I kinda hear a "spinning grinding" noise for a few seconds, then it goes away.
Anybody have any idea what this is? Btw I think my clutch is bad so I've got a new one sitting in my room thats going in this friday...is that the problem or is it something worse?
Gary would be correct in saying it's your throwout bearing. Did you buy just a clutch disc or a clutch kit? The kit should contain a new throwout bearing.
Gary 420A RS said:
that would be your thowout bearing either its clips broke from the fork or its just not on right... its about a 30$ part from
http://www.dsmtuners.com/forums/showthread.php?t=134122&highlight=noise+clutch+engaged
http://www.dsmtuners.com/forums/showthread.php?t=154845&highlight=noise+clutch+engaged
maybe one of these will help you :thumb:
thanks guys...yeah I did see these posts dont think I didn't search...however they refer to when your clutch is NOT engaged...
my noise happens when it IS engaged...figured there would be a difference
ALSO, yes I've got a full clutch kit sitting here in my room...so if it is the throw out bearing well then....guess i'll have a new one this friday
98eclipseRS said:
make sure you use the mitsu factory throw out bearing. it is plastic lined instead of metal lined.
i shouldn't use the bearing that came with the ACT clutch? i take it that's what you're saying...mitsu OEM is better?
