ShawnsGarage
- 354
- 2
- Jul 19, 2008
kannapolis,
North Carolina
Well after problem after problem I have decided to do a rebuild at 160k. I am going to list the componets im using in the build below. The motor is a n/a 1g 6 bolt and I am building it for a DD. Right now I am leaning toward running it n/a to help with reliability but I mainly need opinions on Pistons. I want to be able to slap a small(14b or 16g at low boost) turbo on it later down the road when my funds are right. But for time being it will be n/a. Your thoughts are greatly appreciated.
Top End.
BC springs and retainers.
SS valves.
Bronze guides
Viton valve seals
3g lifters
Bottom end.
ACL tri-metal Race main and rod bearings
OEM BSEK
OEM timing kit
Topline water pump.
OEM oil pump
2g .20 topline ceramic coated pistons.
Top End.
SS valves.
Bronze guides
Viton valve seals
3g lifters
Bottom end.
OEM BSEK
OEM timing kit
Topline water pump.
OEM oil pump
