98GSX_MTX
- 48
- 1
- Nov 23, 2004
Midwest,
Wisconsin
Okay, I have a ported FPB28 and I have it fairly tuned with the DSMLINK. With this turbo I am flowing 36LBS of air at 22 PSI. The main thing that I like about it is that it HITS HARD. I am attaching a DSMLink log for you to view. (You will need to rename it from a .txt file to a .dat file) When cruising at 3k rpm (not boosting) and then going WOT I get 25LBS of airflow (not boost) within 1.3 seconds. In 4.5 seconds I have 35LBS.
Now I have been reviewing a ton of other logs. Everything from EVO3 16G to the SCM50 trim and nothing I can find even comes close to moving that kind of air that fast. Many can say "I get 16 psi by xxxx RPM" but PSI means squat. Airflow is what mattters. Hell most of the SCM logs I viewed weren't even flowing what my BIG 28 does on top end unless they had cams yet their down low was spongy at best.
I am looking for the next turbo up that HITS HARD. I know some of you will say an FP GREEN but I have ridden in a DSMLink tuned car with a green and even though it pulled nicely up top (45LBS) it definately didn't feel snappy between shifts and such.
I guess I am looking for actual reviews and if possible LOG FILES to show how your turbo performs. To me the SCM50 and FP GREEN are just too sluggish to trip my trigger. Does anyone have any TDO5, TDO6, and TDO6H 20G log files or reviews to provide? Please let us know how much air you are flowing and whether or not you have cams and such.
On stock 7 bolt head and cams, I basically have instant spool move 36LBS of air. I am looking for something that can move 44LBS yet still hit hard. Outside of a minimal EVO3 16G upgrade what is my best option?
