foxyspyder01gt
- 77
- 0
- Feb 1, 2009
servery,
Kansas
*sighs* it's been a long 3 months not being able to drive my 95 Eclipse GS-T... The back Story i just got my inheritance 3 months ago and was looking for a DSM to drive well i came across this 95 eclipse gst with the 16 g turbo for 4500 the guy said he took care of it and loved dsm and wanted it go to another DSM lover.... Yea he brought the car over i took it for a test drive i knew there was some problems with it after the first test drive and i could tell just by the way it drove that he never took care of it and it need to be saved.
So i bought it and i drove it for a few days well fixing part's that i found wrong like the front engine mount add fluid to the radiators since it was bone dry but i did not have full access to my inheritance since the guy i was living with had to despot it in his bank account .
well i knew the oil pan had to be replaced because it was so dented in but could not do it and guess what i spun a rod bearing so i called up Carz Performance since i did not have the tools to do the job my self and now it just getting fixed i guess there was a lot more wrong with it here is the list of what they are doing to rebuild the engine.
PISTON SET 85.5 MM, .020 9.0CR MACHINE ENGINE BLOCK 450.00
4G63 2G/EVO8
CPPSC7201 1. 00 566.53 566.53 ENGINE OVERHAUL 1,995.00
CONNECTING ROD H-BEAM 2G
4G63 REBUILD CV AXLES 98.00
EAGESP5900MB3D 1.00 365.85 365.85
MITSU MAIN BEARING Hazardous Materials 63.58
ACL5M1219H 1.00 118.85 118.85
MITSU ROD BEARING
ACL4B1185H 1.00 74.85 74.85
MITSU THRUST WASHER
ACL1T1219 1.00 19.85 19.85
ARP MITSUBISHI MAIN STUD KIT
ARP2075401 1.00 55.00 55.00
MITSUBISHI HEAD STUD KIT 2G
ARP2074203 1.00 95.00 95.00
COMPLETE ENGINE GASKET KIT 2G
7BOLT
MITMD973105 1.00 308.48 308.48
MITSU 4G63 FRONT COVER
MITMD327450 1.00 264.83 264.83
TIMING BELT 1G, 2G, EVO8
MITMD326059 1.00 88.39 88.39
MITSUBISHI BALANCE SHAFT
ELIIMINATOR KIT
ENQBEK122 1.00 33.93 33.93
TIMING BELT TENSIONER DSM
MITMD308086 1.00 105.65 105.65
TENSIONER PULLEY EVO
MITMD369999 1.00 45.05 45.05
EVO IDLER PULLEY
MITMD156604 1.00 45.10 45.10
OIL PAN 2ND GEN 4G63
MITMD332043 1. 00 225.00 225.00
BREAK IN ADDITIVE
LUC10063 1.00 9.67 9.67
10w40 OIL
KEN1040 5.00 6.20 31.00
OIL FILTER
MITMZ690116 1.00 5.54 5.54
HEAD GASKET 4G63 85.5MM BORE
.051"
COMC4233051 1.00 85.00 85.00
AXLE NUT WASHER 95-99 DSM
MITMB109025 2.00 4.29 8.58
FRONT AXLE NUT 95-99 DSM
MITMB109029 2.00 6.81 13.62
TIMING COVER
MITMD332865 1.00 57.05 57.05
BOLT
MITMF241309 5.00 2.84 14.20
CLUTCH FORK
MITMD770506 1.00 77.21 77.21
PIVOT BALL
MITMD719602 1.00 12.78 12.78
CLUTCH KIT 2G 2600
ACTMB1XTSS 1.00 515.00 515.00
DSM LOWER RADIATOR
INSULATOR
MITMB906101 2.00 8.33 16.66
oil pickup strainer
strainer 1.00 28.19 28.19
ACT FORGED FLYWHEEL MITSU 2G
FWD
ACT600165 1.00 275.00 275.00
REAR MOTOR MOUNT BRACKET
FWD 2G DSM
MITMD745087 1.00 90.16 90.16
COTTER PIN FOR AXLE
MITMF472087 2.00 0.62 1.24
FLYWHEEL COVER FWD 2G DSM
MITMD195137 1.00 13.19 13.19
LOWER RADIATOR HOSE 2G DSM
MITMB906429 1.00 19.49 19.49
UPPER RADIATOR HOSE 2G DSM
MITMB906428 1.00 18.51 18.51
Shop Supplies 203.44
LAKEWOOD, CO. 80214
7895 WEST 14TH AVE
CARZ PERFORMANCE
Parts : $ 3,907.89 Labor : $ 2,606.58 Tax : $ 281.54 Total : $ 6,796.01
ill be happy to get it back by the end of oct and drive it out to Kansas
4G63 2G/EVO8
MITSU ROD BEARING
MITSU THRUST WASHER
7BOLT
ELIIMINATOR KIT
EVO IDLER PULLEY
BREAK IN ADDITIVE
10w40 OIL
OIL FILTER
.051"
TIMING COVER
BOLT
CLUTCH FORK
PIVOT BALL
CLUTCH KIT 2G 2600
DSM LOWER RADIATOR
INSULATOR
oil pickup strainer
FWD
FWD 2G DSM
COTTER PIN FOR AXLE
LAKEWOOD, CO. 80214
7895 WEST 14TH AVE
CARZ PERFORMANCE
